Ive got a BIG problem
I NEED HELP!!! ive got a gmc sierra and it wont turn over...i replaced the starter, and if i hook the battery charger up to the battery and then turn the key...it sounds like theres electrical feedback. if i turn on the radio it is all static and just sounds like there is feedback, like in a mic. if i dont have a battery charger on the truck, the door chime wont sound, the dome light wont come on, and none of the lights on the dashboard go on......im am totally lost, although i do konw the problem is electrical...
any help is appreciated
I've heard that sound that you describe with a charger. Your problem sounds like a dead cell in your battery to me. If you turn the key and your lights go out, it's a battery. If you turn the key and the lights don't change in brightness, it's a connection.
I agree with NV5600, start with your battery and also check your connections. NV5600 like your tower and beam, truck looks good too. 73, W2MLC.
Voltage = Amps * Resistance
To test a ground, get a test light and hook clamp end to battery positive. Then touch probe end to negitive terminal. if it lights up now you have a ground tester.
Battery and cables are a great place to start looking. Take the cables off the battery and hook them directly to the charger and see if she cranks. If she does then shut off the key quickly and run out and get a new battery. If it doesn't turn over then check the cables for connections and possible burns or breaks in them. Also check the body ground wire.
The battery charger idea is good only if it has enough juice to crank the engine. Just swap batteries with another vehicle or a friends vehicle. Putting a charger directly in line w/o a battery could damage some things. Put volt meter on the battery if it has less than 12.5 volts thats your problem. That won't tell you if you have a load problem but if it has a dead cell it will read less than 12.5 volts. Dirty cable ends can do the exact same thing, clean and see what happens. Hope this helps
