Bad noise from front wheel on 2WD
I have a 1990 C1500 4.3 2WD
Well first front passenger caliper froze and after fixing that I noticed my rotor was warped because of the heat (It was glowing bright red, when the caliper froze). So then I got a new rotor. After I put on the new rotor, the shaking while braking stopped (from the warped rotor) but now I have a bad "squeak" (sound like the squeakier on your brake pads). It first I thought my brake pads were too thick for the new rotor, so I put on some older pads that were thinner, but that didn't solve it. So then I switched the new passenger rotor (and inner bearing) with the driver side rotor and inner bearing, still squeaks. Then I got new bearings for the passenger side, still squeaks. So now the rotor, bearings, and brake pads have all been changed with no luck. The only thing left to change is the spindle (hub assembly). Could the spindle become damaged when the caliper froze causing everything to get hot.
The noise is worse at 40-50mph, but is constant at any speed. I can hear it when I spin the rotor by hand (with out the caliper on).
Do you know what this problem could be, It didn’t start until I replaced the warped rotor with a new rotor (but continued even after I switched the new rotor to the driver side)????
Summer 2002
-Caliper froze on passenger side (broke caliper, wore down bearings and warped rotor from heat)
-Replaced caliper and bearings (still had warped rotor)
-Caliper froze again
-Replaced brake line and bearings (still had warped rotor)
-Caliper did not freeze anymore, but I still had a warped rotor so the truck shook when braking.
Summer 2003
-Replaced warped rotor with a new one on passenger side
-Stopped the shaking when braking, but a squeak started
-Replaced brake pads with thinner ones
-Still squeaked
-Swapped new rotor (with inner bearings, with the driver side rotor and inner bearings)
-Still squeaked
-Installed new outer bearings
-Still squeaked
The passenger side currently has different bearings, rotor and brake pads since the squeaking started.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
