2014-2015 sierra tail light harness
jmoney
I'm trying to replace the tail light wire harness for my 2015 sierra all-terrain. I just need the left side (they are sold left or right side), but my truck's wire harness is one piece and splits to both sides (with one plug for both sides on the terminal).
