2500HD Running rich smell 6.0
Rich427
Hello, I’ve had my 2016 2500HD 6.0 since about last June. It’s been great. Has about 45k on it now. I’ve noticed when it’s running a really strong rich fuel mixture smell. Is this normal? It’s not throwing any codes and it’s been like this since I’ve owned it. Thanks - Rich
i also (Just this afternoon) greased the upper and lower ball joints and outter tie rod. Can’t see where to grease inner tie rod. Did not climb underneath yet to do others.
A live data scan tool could help you confirm if most things are working in correct order. What I'd want to view are the o2 sensors fuel trims. If the long term fuel trims are within about 3-5% of zero and the short term trims aren't going completely crazy, then it's likely running just fine.
If the LTFT were at something like -20%, then that could be a reason for the extra fuel smell from the exhaust but most would think you'd see a check engine light for a rich condition and possible loss in fuel mileage.
Past that you could just have catalytic converters that are working good enough to not set codes but still bad enough to present the exhaust smell. Or maybe you have no cats and a tuned truck, but I'd doubt that lol.
truck is all stock with cats lol
Hooked up the scanner.
LTFT bank 1 and 2 both at 4.7
STFT bank 1 is at 0.8 And not moving much
stft bank 2 is moving more but around 0.0-2.3
That stuff checks out then. At least we know the engine isn't running rich based on the information from oxygen sensors.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,211 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
