Coolant Leak?
firecadet613
Alright, I'll admit it. I'm over anal about my truck. But who here isn't right :cheers: ? Anyways the mechanics who installed my engine made multiple mistakes, and I kinda think its sucking down some coolant now. What I need to know is if my engine is eating coolant would the coolant level be going down fairly quick in the overflow resovior, or could it be very little and only slightly noticable.
Joe
Joe
Ummm simple answer.
If its a bad leak, then yes...you will notice alot very quickly.
If its a small leak, then yes... you will notice a very small amount gone.
If your worried, keep an eye on your oil.
LOL got the answer I figured but was hoping it wouldn't be. If it's leaking coolant internally I should be able to tell by looking at the oil on the dipstick right? It'll be more watery right? I just changed the oil and had to pull my intake plenum to remove the intake manifold bolts and put some sealant on them so it can't suck down any oil, mechanics didn't do that :cheers: and it used more than 1qt in the last 3K miles before the oil change. Oil level appears fine but I'll know for sure when I get to work and check it after work, got the same level parking spot there :sleep:.
Hey Z71 Guy got any pics of your truck? Sounds like exactly the one I want to get.
:cheers:
On another note the coolant level checks out ok, down a tiny bit in the resovior but I took the cap off the radiator the other day and a tad came out.
Joe
Just got back from a quick weekend trip to Indianapolis. Oil Level appears to be ok and not going down at all, that includes some highway trips of about 80 miles each way. Looks like it was the intake manifold bolts not being sealed created the oil usage. I pulled them and sealed them up the other day, pulled out each bolt in the intake plenum one by one and sealed them, with Permatex #2, and reinstalled torqueing to specs before moving on to the next bolt so my intake would not shift. Now it appears that the coolant level is dropping some. It does not appear to be leaking externally which leads me to believe my engines eating it. It has gotten colder out here in Denver. It was in the 80’s last week and has been in the 20s and 30s since then. The coolant level in the reservoir was right above the ADD lettering on the side but has appeared to drop to the middle of the ADD lettering now. Is it eating it or most likely just going into the system due to the temperature change? What’s the best way for me to check and see if I have a coolant leak internally, pressure test it while its cold?
Joe
If your coolant level only dropped alittle bit, its probably due to the system burping excess air trapped in the coolant passages during the first repair, and during your intake fix. I would keep track of it for another few days to a week. If it drops excessively, then you will need to have the system pressure tested to determine where the leak is at. If it doesn't drop or drops very little, I wouldn't worry about it since it does take a few drive cycles for the entire system to be bled of air.
:sigh:
CoolCool. I'm parking it in the same exact spot on the driveway now and will for the next few weeks. Also used a washable marker and marked the line on the overflow bottle that the coolant was at this morning, I'll keep you posted.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 839 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
