Trailer running lights.
Got a issue with the running lights on the 7 pin trailer plug. The turn and stop work fine the fuse is good for the running lights but there is no power at the fuse. I tested with a test light. I took the fuse box off and all looks good nothing corroded any thoughts.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
