Code p06dd 2014 Silverado
Bryson
I have a 2014 Silverado  with 162,000 miles.  And it just started  to pop up a code PO6DD engine oil pressure control performance circuit stuck off  and the oil pressure  is running  at 70. And it stays  on v8 and does not change to v4. Once I  clear the code  it drops back down to  40 pounds.  And everything is  fine.  I was told  to oil pump  need to be replaced, I  heard  cylinders 7 and 8 might be stopped up. Can anyone  help  me with this?
  • 4 weeks later...
I had the same issue mines a v6 180,000 miles, changed the oil pressure sensor and the oil and was working perfect after clearing the code. Try that first it’s a cheaper fix
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
