Just bought a 2019 Colorado z71 and there's been a few times when I turn the truck off and get out the radio stays on and continues to play.
  • 8 months later...
I bought a 2021 a month ago.  The infotainment system has been a nightmare.  Volume goes way up and way down on its own.  Will not shut off when I exit the vehicle..  Reboots randomly.  Sometimes a non- responsive screen.  Sometimes non-responsive controls.  Disconnects from my iphone both with Bluetooth and carplay.  My car has been in the shop for diagnosis and repair 5 times in the past month for problems with the infotainment system.  "Repaired"  three times and the entire infotainment system has been replaced twice.  It is still having the same issues with no resolve.  Are others having the same issues?  Reading the forums it seems to be a common problem with these trucks with no fix.  Who else is having these problems?
  • 3 months later...
I have the same issues on my 2019 Colorado z71 with the infotainment 8” display system. These issues of rebooting started happening randomly in October of 2020, along with the loss of adjustment to volume control. This problem happened after I allowed an over-the-air update to occur. Worst mistake I ever made the radio was fine until that software update. Dealer has replaced the head unit and still it is not fixed. They can’t seem to duplicate the issue. All they really need to do is come for a drive with me pretty consistent with it happening. Funny thing is my phone works fine with the same Apple iPhone and OEM cable on all my other vehicles Subaru, and BMW just not the Chevy that should probably be telling me something right there.  I noticed others experiencing this or similar issues across multiple GM vehicles and model years, this it is a distracted driver issue that GM needs to resolve before someone get’s in an accident and seriously hurt. My guess is that the firmware update applied to the head unit broke Apple CarPlay on the head units. This is clearly not an Apple iPhone or Apple cable issue. The Dealership has tried to correct the problem but looks like I am now at the mercy of GM or third-party software developers correct the problem that they caused with the September/October update. My only other recourse would be to trade in the truck with only 26K on it.
