2020 Sierra 3500HD DIC
I have a 2020 GMC Sierra 3500HD with Roughly 1100 Miles on it. After starting the truck late this afternoon it prompted me to go through a Exhaust Filter Cleaning. Once I got home I put it in Park and proceeded to follow the on screen promos on the Cluster, it went through, cleansed itself and all is well. HOWEVER.....
I no longer have the option to view the Digital Speedo, Trip Meters, EST Fuel Mileage Etc...
I know for a fact this all worked just prior to doing the Cleaning as I had just filled the Truck up with Diesel and reset the Trip Gauges.
I’ve tried turning the truck off, opening the door and locking it, running it up the highway, the 2nd key, went through the infotainment system to see if there was something in there to change but to no avail.
The only thing I can see right now is:
Units
Oil
Air Filter
Brake Pads
Tire Pressure
Fuel Filter
Engine Hours
Trans Temp
Trailer Brake
Def
And the Giant Checkmark telling me my Exhaust Filter is Clean.
any help or a hey stupid, this is what you gotta do is appreciated!
Leave your truck in park and navigate to the options menu in your settings. There you can add or delete what shows up when you toggle through. See if it is somehow unchecked now.
So I’ll try this^^
A little update, the truck now has about 1800 Miles on it and has now gone through 3 Manual Regens. This seems extremely high to me. I ran a 2015 Sierra 2500HD and never had to run a manual regen nor did it regen in such close cycles.
In all 3 cycles, the same issue has happened. I called GMC and the Service guy has no idea why this would be happening and wants me to come In And get it looked at.
The only thing to cure this has been to disconnect both Negatives on the batteries to reset the ECM, which is not practical.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 3,038 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
