brake light switch power
I dont have power to the orange wire at the pedal brake switch.  i have power through the brake fuse in engine compartment. i assume i have a bad (shorted) wire between there and the switch. can someone confirm that has a schematic if there is anything between the fuse box and the switch? Thanks Greg
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
