Hey, all.
First post...here goes.
Need some help troubleshooting a crank no start issue. I tried a search, but didn't find what I was looking for so if this has been asked before please let me know.
Anyway...
99 K1500 5.7 is cranking, but not starting. The steps I've taken so far are:
1) Tested fuel pressure - 55psi.
2) Tested for spark at all the cylinders - nothing.
3) Tested for spark from the coil to the cap - nothing.
4) Tested voltage to coil and ICM - good at 12V.
5) Checked signal from ICM to coil - good continuity.
6) Swapped coils with known good one, twice - nothing.
7) Swapped ICM with known good one - nothing.
? Checked switching signal from PCM to ICM - on with key in off position.
So, I stopped there because based on what I understand the switching signal is only suppose to be on when the engine is rotating. Why would it be on if the key is off?
Check the wires near, and I mean right behind the plugs for the ICM and other related plugs.   Broken wires are not always obvious.   Follow the electricity.
 I once was graced with an intermittent die while running and/or no start.  Turned out to a broken wire that was still connected by sheath and as it would make intermittent contact.   Hit a bump, or wiring get hot, and no run or no start.
Edited by API_ERIC
Spelling
Check crank position sensor or wires to it.
I believe the CPS reads the position of the crank and sends a signal to the pcm which in turn sends a signal to the ICM to tell the coil to fire. The camshaft position sensor can do the same thing I think but usually it will still fire. The CPS is a hall type sensor and when it fails you get a no start condition as with the ICM as well.
Look up the diagram for the ICM and see which one is the signal wire (12v) from the pcm and have your girlfriend or a buddy turn it over while you probe that wire with a multi meter.  Every time the cps tells the pcm to send the signal to the ICM to fire the coil, you should see something on the multimeter. If you don't see anything then try changing the CPS. Another way is if you have a scan tool that reads cranking rpms, it should read zero if the cps has failed.
One other thing I would suggest it to read the codes somehow and post them. The crankshaft position sensor can have an effect on starting if it has completely failed as well. Best read them codes or else start dumping money on parts
Agree on crank sensor/cam sensor. Also you can test it with a voltmeter but the engine has to be cranking when you test it (hall effect). Have a buddy crank it while you test the crank sensor for voltage. Or just swap it out and know you have a new crank sensor either way. I believe it should read 5 volts! Peace and good luck!
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 338 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
