Chevy Silverado 1500 . Year 2015.
for a few weeks now once a week my battery drains completely. Plus for few months when I start my truck the radio and sound doesn’t work. I have to restart the car 3 times before I get sound .
this morning I drove it for 10 minutes turned it off and then it wouldn’t start again battery drained.
dealership keeps saying bring it in sounds like computer failure ?doesn’t to me but I figured I’d do more research first
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
