Ok ladies and gents. I’ve seen multiple forums posts about it but always talking about replacing shocks for leveling and lifts. I have a fully stock 2014 1500 Silverado high country.  It has 60,000 miles on it and unfortunately is starting to ride like an empty dump truck. I know part of it has to do with my the BFG ko2. Although not all I wouldn’t think because they are factory size, 275/55R20 and 8-ply. What shocks are going to give me the smoothest and best ride on the highway and back roads? I don’t off-road in the truck and here and there towing with a boat. Thanks for any help
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
