Classic
k1500chevy97
That cat needs to come visit my dog Sha-Kill. It's been awhile since he's ate a cat, and that one seems fat enough to fill his craven! Hehe. :lol::D
d**n, relentless aren't you wingnut?
Not like I'm not relentless. :D
No, I'm bored. :flag:
But I get off in about 5 minutes, and you will not have to deal with me for around 16 more hours. :lol:
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
