I’ve recently put a light bar on my truck. I ordered a Totron wireless remote so I can use my homelink to control the light. But I can’t get the Totron to control the light. I used the harness that came with the light. Does anyone have any experience with the Totron wireless remote? Does it only work with Totron light bars or do I have to use their harness for it to work? Thanks
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
