2018 silverado Radio resets to 89.7  after  shutting of truck and getting out. Next morning When starting up there it is back to 89.7. Have reset factory radio settings reprogrammed favorites still resets back to 89.7. ... Anyone got a fix for this?
Edited by Darren Brock
Forgot to put year of truck in
    Gkistler
    Gkistler
  • Who's Online   6 Members, 0 Anonymous, 921 Guests (See full list)
