Cross Fire 350 Pics
pacodiablo
I need some pictures of an original 350 Cross Fire Injection engine from a Camaro. I need to see the block as well as the valve covers and all of that. I am working on a scale model CF engine and need to see the colors of the block and the equipment. Thanks for any help.
Sh!t....Those were easy to find.....Finding a picture of an Escalade EXT with a load of gravel in the back of it is proving to be exeedingly difficult though.
:devil: Go figure. :D
Too bad I don't have Photoshop at work. :devil:
Those crossfire engines required some tweaking to run good :devil:
I believe Crossfire was only available on a 305 in the F-body though :devil:
Yup, but everyone thought they were pieces of junk. If you knew how to work on them they would run.
That is what I have heard from others.
I don't know what the engine is...I assumed it was a 350 since they were also in Corvettes. Didn't know the system was on multiple engines.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 842 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
