I have a 2020 chevy silverado 2500HD and recently purchased a fifth wheel camper.  Is there a replacement part to install a third light with camera?  I'm looking to have the camera pointing to the truck bed so it will be easier to hook up my fifth wheel.  I did find sites that say OEM 84487008 is the part I need but when crossed checked with GM, it states this part will not fit my truck.  Anyone have any idea's or suggestions to finding this?
Thanks
Edited by 99silveradoz71
