Odd question, but is anyone running dodge wheels? Same bolt pattern. Only difference I see is my Chevy wheels have 24mm offset and the dodge wheels have 19.1mm offset.
I haven’t purchased yet. Found some nice takeoffs with tires. Would just replace the ram center cap.
Make sure the hub size is same or bigger. If its smaller, you have to machine the wheels. If bigger you can get some rings. I made the mistake with kids honda with subaru wheels. I was happy to see same bolt pattern, but sub wheels had much smaller hub and would not go on. Wasted a bunch of money on that one...
Sent from my SM-G975U using Tapatalk
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,313 Guests (See full list)
