1st day with my 2021 LT Trail Boss and my Lab got hungry....
Chewed up the rear cupholder on console and the rear trim panel.
Anyone know (without having to go to dealer) if an online schematic and source is out there?
I have spent some time looking but everything is very vague and not very specific.
Yes; the dog is still alive.....Owner left a milkbone in the cupholder so I can't blame him for my stupidity.
Any help would be appreciated!
Gmpartsdirect has schematics for all parts.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
