4L80E Question
Is the tranny (4L80E) a 4 speed w/overdrive(torque shift) and if so should it shift quick between 3 and 4 like 1 and 2, 2 and 3? It shifts quick from 1 to 2 and 2 to 3, but when it shifts between 3 and 4 it shifts slow and then the slow torque shift. Still have warrantee left if this is a problem. Thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
