If anyone can share a lead, my search continues to find little to no help in my effort to upgrade the fuel switching between the original seat tank to the two auxiliary side tanks that were the trend in 1972. I have a brand new motor, trans & transfer case just installed. The fuel switch has very little movement but did allow for fuel to flow. It has stopped all the sudden from letting the side tanks draw fuel.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
