I have been experiencing a metallic rattling noise coming from behind or around the cluster area.i have also found the knee bolster bolts loose numerous times as well as other rattling ticks from that area. I have duct taped the clips zip tied anything that moves and wedged foam padding in any area possible and have fixed those noises...but one still remains, just not sure if im confident enough to start taking apart the dash. Any suggestions? It sounds like it could be a loose screw sounds very similar to the 4 knee bolster bolts. Dealership said they couldnt hear anything. I am sure its behind that area because when i put pressure on the clear plastic cluster it stops but defintely sounds from behind...edit- found 2-7mill bolts loose same as knee bolster bolts behind gauge cluster they were more than an 8th of an inch loose..spent an entire year with this and was an easy fix didnt have to unplug gauges
Edited by Kyle Dewar
Fixed
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 577 Guests (See full list)
