Hello, i have a 2014 GMC Sierra 1500 SLE with a dead touchscreen. It went totally black while driving, which has happened before. however usually it will come back after shutting the vehicle down and re-starting. Not the case this time. The radio still works, and can be con trolled through the steering wheel controls. But the screen, volume controls and even the CD eject button are all non-functioning. I checked connections on the HMI module as well as the screen and radio control unit. Checked all fuses. Performed reset of radio by pulling the fuse, as well as global reset by touching positive and negative battery cables together (after disconnecting of course). No change in status. I also attempted to replace the HMI module with one purchased from Ebay, however i quickly realized that need to be programmed before it will work. so.... looking for suggestions or options. I have an appointment with my local dealer but that is 3 weeks out. Any help is greatly appreciated... thanks!
    TopBo
    TopBo
  • Who's Online   2 Members, 0 Anonymous, 1,263 Guests (See full list)
