Hello,
New to forum. I am looking for part # 23145191 Switch panel.
I am trying to install AUX switches on my 2018 Silverado 2500HD 6.0L Z71 truck. I know they did not come installed/wired, but I do not want to hack my dash up to install non-oem switches.
My truck has TC/bedlights/HDC switches currently.
If anyone can help, it would be greatly appreciated.
Thanks
Eddy
  • 8 months later...
I know it’s been almost a year but if your still looking for that switch panel they updated the switch panel part number. It’s 84347210. They are about $55.
