I have a 2021 Sierra AT4  3.0 Diesel Duramax 2” lift stock GM  suspension, Would like to know if anyone has done this? Does it rub? Pic?
I don’t want to add any leveling kit or lift it anymore than wat it has 07D83B3B-535E-47C3-A19F-A9A31F696B89.thumb.jpeg.fc46b6691e91243cb3d2500a260cd708.jpeg
Edited by Dae0311
Well I dont know about the GMC  but that is only 32.58 tall tire , I have a Silverado RST and I put on TB lift and I put on 285/50/22 Nitto Ridge Grapplers which are 33.22 tall have have no rub at all.
I am getting ready to pull the trigger on the same truck and am looking to put those exact tires on it.  For clarity, the pics are showing the stock wheels and tires with 275/65 R18s?
Yes those r the stock 18” rims & tires r 275/65/18 Good Year Duratrac
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,660 Guests (See full list)
    • I have 2 choices.
