SAS thinking of one
Iam thinking of doing a swap, Is it that hard ?
Any help would be great. Located in NE Pennsylvania....
What Donor truck to use? would like a 12 bolt front axle .
Anyone selling parts ?
Anyone have pics that has done this ?
1988 1500 IFS 241 T400 4.3
THANKS look foward to using this forum ..
www.paragonap.com
www.jeepz.com
Its like the adage, if you have to ask the price you cant afford it. Figure on spending several thousand dollars and a looooooong time fabricating, cutting, and welding the parts of your truck that you most particularly dont want to have fall off when driving. I know there is a company that sells a 'kit' for the 99+ chassis which runs in the $5-10k range, but its still mostly a custom project.
well, i was thinking ,,
Cut all the ifs out. start with a clean frame. Measure where the new leaf springs will go, get them mounted / shackles ..
Bolt axle in setting correct pinnion deg. Fab new shock mounts.
ditch the ideler arm , run a link from the pitman to a tie rod of the solid axle.
new drive shaft. break lines , lock out hubs...
So lets start with what iam missing...
    JustusTX
    JustusTX
  • Who's Online   4 Members, 0 Anonymous, 466 Guests (See full list)
