We have a 2017 Suburban LT and the driver information center has gone blank. It did this once soon after we bought it but came back after sitting overnight, this time it has been blank for a few days. I pulled the battery ground for about an hour, it lit up briefly after but went out before displaying any info. I'm going to try to track down the fuse this weekend but does anyone else have an idea before I bite the bullet and take it to the dealer? Not having any luck with searching for this issue. Thanks
Update incase anyone searches for this in the future. I checked the fuses and re-seated the connector on the back of the display with no change. After 2.5 hours of troubleshooting, the dealer decided the display itself has failed. Looks like $1056 to get a new one, program it and install it.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
