Transmission is getting really hot over 240 degrees. It wont shift right keeps getting stuck in gears or wont shift.
Can you give us some more information.  Year of vehicle, transmission 6, 8, or 10sp.  How many miles are on it?  When was it last serviced?  Getting hot just normal driving or when towing/hauling?
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 1 Anonymous, 591 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
