BDS Shocks
Hi all, I was just curious if anyone has used or is using BDS Shocks. I am considering put a set on my 2000 Z71 to replace the factory shocks.
If anyone has any information on these shocks, the info would be appreciated.
Thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
