I just picked up my new Tahoe, but it didn't come with front parking sensors or surround vision. With the current COVID delivery problems I chose to take whatever they had instead of waiting months for a new one.
Does anyone know if I can have the OEM front parking sensors and maybe a front camera added?
Edited by fatkat
  • fatkat changed the title to Adding front parking sensors and camera?
  • 1 month later...
I’m wondering the same thing.  I didn’t even realize they came without front sensors.  Did you find a solution or answer to this issue?
  • 3 months later...
On the same boat for my RST.
kinda sucks that it’s standard now on all 22’s well the front sensors at least.  I want to do both I’m sure there is a way just need to figure out how to connect the camera wiring to the head unit.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
