Got an 07 Silverado 1500 with lift kit. Not sure on lift. It had upper cognito control arms, aftermarket knuckles and rear fox shock absorbers. The problem I’m having is that I replace everything in front end upper/lower control arms, inner/outter tie rods and ends. Took to get alignment done after replace with new parts and they couldn’t do an alignment because the inner tie rods were all the way bottomed out to the end of the tread could adjust anymore. Anyone have an idea on what I need or to to fix this problem!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
