I am making a custom tailgate LED strip for my truck and need to tap the 12v switched wires to control the strip. I need separate lines for the turn signals since I'm doing sequential animations for them, so I can't use the trailer connection since brake and turn are combined. The most logical source of these switching inputs seems to be the tail lights.. Does anyone know the pinout for the tail lights, specifically the LED ones? Also, is there a recommended fuse to tap for such an accessory? Thanks!
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 788 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
