My 06 Silverado shut off while idling, and the DIC says low engine power. Codes P0068,P0103.  It is a 6.0 2003 motor.
Try unplugging the MAF and see if it runs. It may take a few tries to start it.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
