I want to lift my 14 silverado 4wd with a 6.5 or 7 inch lift. The replacement uca brand i went with is moog to replace the stock aluminum uca's. I dont want a spacer kit i prefer to purchase a kit with lifted struts instead(Zone or Rough Country).
Will the moog uca's fit with lifted struts?
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
