Hello, everyone! Hope you're all doing well and excited for the Holiday season.
I'm very sorry for yet another "what's that noise?" thread, tried to shuffle through the Troubleshooting section to pinpoint exactly what it is I'm hearing, but was unsuccessful.
Just as luck should have it I found this video on YouTube that is the EXACT engine noise I'm experiencing:
https://www.youtube.com/watch?v=EZAj8y7xm9s
I've been more concerned with how rough the engine sounds right at startup, but the other day I did also get the exact "chattering" noise that is present in this video (albeit for a quick second, it sounded like acorns falling through the engine bay).
It's been a little chilly in Michigan the past couple weeks, so obviously I expect startup to be a little tougher on the ol' 5.3. However, I do not recall it ever sounding like this, unless maybe I'm just more paranoid than ever (if that's even possible)? Fortunately, it does idle normal within a couple seconds of just warming up, and I really don't see any change in the drivability whatsoever, no check engine light, etc.
While I hope to be able to identify what exactly this is, the answer I'm really hoping to gain with this thread is: should I be worried? I love this truck, it's been reliable and dependable over its 7+ years in our family, I really, really have no desire to get rid of it. I worry because a big repair right now would really, really suck. My main concern is if I'm really jacking something up  by doing my morning commute every morning when there could be something wrong that I don't know about.
Very sorry to ramble, hope you all can help me out! Again, thank you so much for taking the time to check this out.
If its the same as in that video, sounds like an exhaust leak?  Possibly broken manifold bolts.  Pop the hood and check them out if you can see them.  Any bolt heads broken, stands a chance you need new bolts and gaskets.
I would re-program the computer ($50) or use an OBD2 AFM disabler ($100), and then I would do a motor flush using "motor medic". After that, change the oil every 3,000 miles religiously.
If that doesn't solve the problem, pull the valve covers to see which rocker has slack. Then pull a head, and drop in a new lifter. Not all of them, just one. The whole job takes a day and costs $100. If you don't have the tools or a manual, the whole job will take a day and maybe $220.
Absolutely. It could be an exhaust leak. I would expect a CEL if that was the case, but maybe not. My 2003 had a busted manifold bolt and I was getting a bank 1 catalyst below threshold code.  I easy-outed the bolt and threw another one in. Even with thread-locker, I have to re-tighten that same bolt twice per year, otherwise I get a tick and a code.
I am so glad you mentioned this, completely slipped my mind! I will absolutely check this out and report back. Thank you so much! 🙂
Definitely could be a possibility. I remember reading about this problem last year when I was diagnosing my failed radiator/water pump.
Appreciate your response, Supreme Pizza, thanks a lot! Got some time off and will definitely look into troubleshooting the motor. Been very religious with my oil changes, curious to see if flushing the motor will help. Will take what you said to heart, not sure how involved I want to get (will find out when I see what's wrong), but if it's the required preventative maintenance and will save me some nasty repair bills, I'm all for it. 🙂
Hey all,
Just wanted to post an update/resolution to this thread for those who view it in the future and have the same noise at cold start.
Newdude and Supreme Pizza are correct, it was an exhaust leak. I had three broken exhaust manifold bolts on the passenger side. Replaced with new bolts and gasket and the problem was solved. 🙂
Edited by OffTheAir
  • Like 3
3 hours ago, OffTheAir said:
Hey all,
Thanks for the update.
I'm glad to hear that it all worked out well for you.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
