NASCAR reduces provisionals
Elwood
by Fanball Staff - Fanball.com
Tuesday, January 6, 2004
News
NASCAR will take 38 cars (instead of 36) based on qualification times, forcing two more drivers to make the show on speed. The other major change in the system is the elimination of “uncharged” provisionals for teams in the top 25 in points.
Views
Provisionals are needed to insure that a stray blown engine doesn’t keep the superstars from competing, but the more drivers who make the show on time… the better.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 757 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
