LOL
pacodiablo
Once there was this guy who
Saw a girl hug a sign on her way home from school
And when she finally came back
His curiosity had gotten the better of him
He said that it was from when
she hugged the sign so hard
Mmm Mmm Mmm Mmm
Mmm Mmm Mmm Mmm
Once there was this girl who
Hugged a handicapped parking sign
then went on Christmas break
And they wondered if she would ever come back
When she came back
Pictures were taken
And she became a legend
Mmm Mmm Mmm Mmm
Mmm Mmm Mmm Mmm
But both girl and guy boy were glad
But did not know each other existed
'Cause then there was this guy whose
Videos and pictures made him into an LS1 phenomenom
And when they went to the archives
They shouted and posted all over the forum
Noone couldn't quite explain it
She'd always just done this
Mmm Mmm Mmm Mmm
Mmm Mmm Mmm Mmm
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 779 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
