2017 Silverado 1500 - 5.3L
A few months back my battery died.  Upon putting in a new battery I had a code appear saying check power steering system.  Unhooking the battery for a few hours and hooking back up made no difference, message appears each time the truck starts.  A week or so ago another message appeared saying to check power steering system and steering assist may be reduced.  I have no issues turning the wheel.
Now the wipers quit working.  I checked the two bcm fuses the the fuse in the fuse box under the hood.  All are fine.  I pulled the cowl off and checked for power at the wiper motor when I have the switch for the wipers to run.  The ground at that switch is good, but no power on any wire.
All other functions of the wiper switch such as washer and turn signals work fine.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
