Last month I spun the tires a little pulling into traffic, and the traction control and ABS lights come on in the dash.  I tried to reset it by disconnecting the battery to no avail.  Everything runs and sounds fine otherwise for a truck with 100K on it.  So now its at the dealer to look into it, as well as replace the airbag, finally.  09 Silverado 5.3 2WD   fwiw
Question- does traction control function have anything to do with the TCM? Or ECM?   The reason I ask is when the truck was nearly new I had the AFM programmed out of it and a tune done on the TCM and don't want to loose those tunes!  Are they likely to want or need to mess with those modules?
Thanks
The ABS/Stabilitrak lights are only with the ABS module. The TCM or PCM won't set a ABS light.
Thanks CamGTP, that’s a relief.   I’d heard of bad problems after reactivating the AFM after years of inactivation.
Edited by spikesputnik
I figured as much. Taking it to the dealership is likely the most expensive place to take it as well.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,001 Guests (See full list)
