Hi,
I would like to add a volt and oil pressure gauge to my 4.8 Vortec. I'm willing to go to the pillar or dash mount, can someone recommend
a brand or supplier? thanks in advance, G.
Glowshift is pretty decent or just do the OEM gauge cluster swap and you are good to go
2007 - 2012 Chevy Silverado & GMC Sierra Instrument Cluster Repair (Gas, 6-Speed  Trans)
There are some things you have to do for it but honestly off the top of my head I cannot remember. Just search for "6 gauge cluster swap nnbs" are you will probably find the information you want.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
