roof rack question
Does anyone know if you need a luggage rack to attach a Kargo Master rack to or can you mount it directly to the roof? I'm new here so if someone can give a little help or point me in the right direction, I would appreciate it.
I don't know, I've never heard of one of those racks. You might not get many responses if no one knows anything about them.
Hopefully someone with some experience with them can give you an answer.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
