Rough Country sells a plug in module that you enter the stock and new tire sizes via computer and it adjusts the computer accordingly. You can spend a lot more on a Pulsar LT and that also has the option of changing tire sizes and several other things. I picked up an open box Rough Country module off ebay for about $80 off retail. I had seen too many weird issues/complaints about the Pulsar for me to want to spend over $500 for it and it doesn't give you any performance gain, just throttle adjustment.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
