GO PATS
Worktruck
WooooooooooooooooooooooooooooooHooooooooooooooooooooooooooooooooooo The PATRIOTS ARE IN THE SUPERBOWL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Sorry about the yelling but, I'm just so excited!!!!!!!!!!!!!!!!!!
BBBOOOOOOOO!!!!!!!!!!!1 :cheers:
Yeah I was rooting for the Colts. I still haven't gotten over that whole Tuck Rule thing, so as a Raiders fan I have to root against them. But dang I have to say, they are awesome this year.
But I'll be pulling for the Panthers. GO CAROLINA!!!!!!!!!!!!!!!
Neither game surprised me this week as I called the winners for both games when the match ups were set.
I pick the Pats to win the big one,17-13 and there will be one score either made by a defense or significatnly set up by a D,specifically inside the opponents 20 yard line.
Now is when I'm really thankful that I picked up that 54" Phillips wide screen HD a few months ago because it will make the game that much more awesome.
I'm pulling for the Panthers too after all the crap I heard & saw about the D@mn Philly fans while in NC earlier this past week. Itwas nerve wracking. :cheers:
I didn't catch the game though, who won?
The Panthers won Jeremy.
It's going to be a defensive oriented game and it doesn't matter to me who wins but like I said in my first post,I pick the Pats in this one.
Booooooooo, Hisssssssssssss!
Didn't surprise me either, but I sure was pullin for the Colts. Now all 3 of the teams that I was pulling for are out (Titans, Packers, Colts). :cheers:
Gotta love the league right now though ... so many of the teams are so evenly matched that one little screw up or one advantage to a team (like the Pats playing in weather they're more accustomed to) can be the difference! Anyway, I don't care who wins the 'big un' .... I just hope it's a good game. :wtf:
    • If it has a stick I can have fun with it. When my wife first got her Acura years ago I used to tease her about it. I was only interested in muscle cars. They’re gone now. So once a month I drive the Acura. Every once in a while I’ll take it to Redline. But just normal driving on some twisty back roads usually does the trick.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
