2016 Chevrolet Silverado 1500 LTZ
-$40,000
-54,****** miles
-6.2 Liter V8
-8 Speed Automatic transmission
-LTZ Package
-Heated/Cooled leather seats
-Heated Steering wheel
-Apple Carplay/Navigation
-Mcgaugheys Dropped
-24” Infamous staggered wheels
-Brembo 6 piston calipers/4 piston brembo rear
-AFE cold air intake
-Carven R exhaust
-Flashpaq tuner to delete eco mode
