When I use my turn signals (either direction) my rear lights act as if I turned my hazards on. The front turn signals operate as they should. I checked all fuses but didn’t seem to find any specifically for the turn signals or hazards, brake lights work properly and all the bulbs are working properly. Any info would be appreciated.
16 hours ago, Cordo said:
Well I solved my own problem. It was the first thing I over looked and it was the wiring for my third break light for my topper which I took off for the summer. I am sure this is common knowledge but if you have an issue I would look into anything after market.
