can't stop without abs coming on
Posted this to another forum but being impatient for an answer I am also going to post here.
Pick up my 97 K3500 from the shop after having new rotors installed. Stops great till I get to about 3mph than the abs comes on. It doesn't matter how fast I was going or how hard I brake it always kicks in just before I am stopped. Weirder yet if I turn sharp (like turning into a space in a parking lot), and don't even touch the brakes, the abs pump starts. I know it muxt be related to the new rotors, any ideas as to a fix?
tia
not to sound dumb,
But are do the sensors "read" the meatl on the inside of the rotor...if so, and the wriong rotors were put on (say they have more or less notches in them) the computer would think the wheels are spinning at different speeds, and engage the abs..
Mike
There is a TSB for this, but don't remember K3500 listed.
Rust inbetween the ABS sensor and mounting surface.
Remove, scrap off rust, paint or coat with protective.
Also, like mentioned, mud/dirt/metal filings/etc get stuck to the sensor and gear. Clean it, but careful, as most spray cleaners (brake type) will melt the ABS sensor housing.
Had a similar cituation on a customers car and it was caused by loose pick-up for the wheel speed sensor. Make sure the sensors are bolted down tight and that the same amount of notches are on the reluctor ring. Good luck
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
