Question Anyone. 2016 GMC Sierra 4x4 5.3L. Can you replace the Throttle Position Sensor clipped to the side of the Throttle Body without having to replace the entire throttle body. I can't find a stand alone P/N for the TPS from year 2014 onward even though it's attached just like it is on a 2013 and older 5.3L which there is a stand alone TPS part available.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
