So I decided to tackle my eiback coilover install myself. I found a DIY garage in town.  the install was pretty straightforward. As I left, I listened for any noise from the suspension and could not hear anything. I checked again in my neighborhood and I could hear a clinging sound. there were only five or so nuts/bolts involved. Do you guys know if I need to get the truck in the air to torque the upper and lower strut mounts or the swaybar connector?
Any help would be greatly appreciated.
Edited by ReggieH
Left out body of poar
6 hours ago, Transient said:
Are you sure the sound isn't coming from the collar on the driver side half shaft?
 I am not. Is there a way to differentiate that?
I guess I assumed it was the suspension and not the axle. I thought I was careful securing the knuckle. Although in order to install the new coilovers I did have to move the knuckle towards me more.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 566 Guests (See full list)
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
