Does anyone know if there is a kit available to relocate the satellite antenna?. I was able to do so on my 2023 by locating the connector behind the glove box, however the 2023 is different. Any advice would be appreciated, as when I have my truck camper on I no longer have satelite radio.
Are you trying to remove the factory roof antenna? You'll have a hole in the roof if you remove it. If you want to add an aftermarket one and leave the factory one in place, you can remove the driver's side A pillar trim and about half way up you can find the OnStar and XM antenna connections.
